Ricambi
Nessuna parte specificata.
Exploratory disassembly of the HP EliteBook x360 830 G7 business-class notebook for the purpose of assessing repairability. Performed 5/21/2020.
The laptop feels sturdy. External case parts are metal, with generous use of rubber for points of contact (feet, display, etc.).
The laptop isn't ingress-proofed, so gaps in the keyboard and lower case—including ports, vents, speaker grilles, etc.—may allow water damage or particle buildup.
The lower case is held in place with five Torx screws and some plastic clips.
The screws are all captive, eliminating the chance of losing them.
The clips are sturdy and require a little force to disengage. They don't seem likely to break over the lifetime of the device.
Nothing is left in the lower case, making for an easy and inexpensive replacement if it breaks.
Many components in computer itself are immediately accessible. Flat design makes for easy, independent replacement of interior components.
Several important components are available for removal as soon as the lower cover is removed.
Pictured here: RAM, battery, SSD, fan, heat sink, and wireless card.
The RAM, SSD, and wireless card are all industry-standard parts, allowing for easy consumer replacement or upgrading.
RAM and SSD are covered by metal shields, held in place with metal clips. Both shields have a pull tab, which is conveniently labeled.
All the above components including the battery are held in place with Phillips screws and / or clips. The fan and heat sink use captive screws.
Once the battery is out of the way, the trackpad and CMOS battery are available for removal.
The ports on either end of the board are under brackets—one plastic, one metal. All ports except the DC power port are soldered in place, meaning users will likely not be able to replace them on their own.
Almost every connection port, screw hole, and cable on the main board is conveniently labeled.
The two speakers are connected with a wire that runs underneath the motherboard, so they are not accessible until the motherboard is removed.
The EliteBook 840 G7 has a similar speaker design, but instead of routing the cable underneath the motherboard, the cable clips to the bottom of the battery, making them accessible as soon as the lower case is removed.
That said, truly critical components like the battery and SSD take priority over speakers. So if something must be buried under the board, a speaker cable isn’t the worst choice.
The WWAN antennas are also available for removal at this point.
The display is accessible as soon as the lower case is open.
The display must be opened from the top so that the bottom end can slide out. Starting from the base will likely break clips and maybe a board.
The webcam slider provides a fairly safe access point for a tool. The thin adhesive is fairly easy to slice through.
The plastic bezel did separate from the display in a few places during removal.
The display is quite easy to disconnect, and no cables or components are in danger during the prying procedure.
The display houses no additional components, allowing for quick and easy replacement.
Once the display panel is removed, the microphone, ambient light sensor, and camera assembly are accessible. Though some are secured with copper tape, which may be a challenge to remove and replace intact.
The HP EliteBook x360 830 G7 earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
The battery, SSD, RAM, and display are easily accessible and removable.
Almost all moving parts, including the speakers, trackpad, and fan are modular and can be independently replaced.
All screws are standard Phillips and Torx, and many are identical, preventing damage from accidental misplacement.
Many parts and cables are labeled.
Manufacturer provides free user-accessible repair documentation.
The keyboard, a common point of failure, is not independently replaceable.
Most ports are soldered to the main board.
Altre 3 persone hanno completato questa guida.
2 Commenti
very insightfull. Learned more about A+ in these 15 than my “get yours here” course taught me when I was a kid. The course has nothing of substance and was made so boomers would know how to use the printer. The post is motivating me to find some nice amd laptops I can open.
My only suggestion would be to include the manufacturing date and or link to a spec sheet and where we can possibly buy this the reviewed unit. Good deeds need to be financially sustainable or they won’t survive. <— just disregard what I just said, I’m just ecstatic because I came from a parts site charging 80$ for an acer aspire v5 fan.
Hi! If my laptop is not LTE ready - can I add WWAN antennas mentioned in step 5 and WWAN module? Is it enough for full LTE or I must disassembly screen part too?
