Salta al contenuto principale
HP EliteBook x360 830 G6 CMOS Battery Replacement
Cosa ti serve
  1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Unfasten the back cover: passo 1, immagine 1 di 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: passo 2, immagine 1 di 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: passo 2, immagine 2 di 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: passo 3, immagine 1 di 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: passo 3, immagine 2 di 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: passo 4, immagine 1 di 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: passo 4, immagine 2 di 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: passo 5, immagine 1 di 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: passo 5, immagine 2 di 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: passo 5, immagine 3 di 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: passo 6, immagine 1 di 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: passo 6, immagine 2 di 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: passo 6, immagine 3 di 3
    • Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
  7. HP EliteBook x360 830 G6 CMOS Battery Replacement: passo 7, immagine 1 di 1
    • Remove the CMOS battery from its housing by pulling up the small, black plastic tab that is holding it in place.
Conclusione
Brody Reder
Membro da: 04/02/24
301 Reputazione
3 Guide realizzate
IUPUI, Team 3-3, Harley Spring 2024 Membro di IUPUI, Team 3-3, Harley Spring 2024
IUPUI-HARLEY-S24S3G3
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 25
Tutti i Tempi: 54
