Salta al contenuto principale
HP EliteBook x360 830 G5 Touchpad Replacement
Cosa ti serve
  1. HP EliteBook x360 830 G5 Touchpad Replacement, Back Cover: passo 1, immagine 1 di 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 Touchpad Replacement: passo 2, immagine 1 di 2 HP EliteBook x360 830 G5 Touchpad Replacement: passo 2, immagine 2 di 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 Touchpad Replacement: passo 3, immagine 1 di 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 Touchpad Replacement, Touchpad: passo 4, immagine 1 di 1
    • Use a PH000 screw-bit and a screwdriver and remove the six 2 mm screws securing the touch pad bracket.
    • Remove the touch pad.
Conclusione
Un commento
не подробная инструкция. при снятии на данной модели возникает куча косяков, которые могу привести к порче оборудования
Vladislav Orlov - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 266
