Salta al contenuto principale
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
Cosa ti serve
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: passo 1, immagine 1 di 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 2, immagine 1 di 2 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 2, immagine 2 di 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 3, immagine 1 di 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: passo 4, immagine 1 di 1
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 5, immagine 1 di 1
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 6, immagine 1 di 1
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
Conclusione
Ashia Lewis
Membro da: 09/03/21
246 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 41
Tutti i Tempi: 743
