Salta al contenuto principale
HP EliteBook x360 830 G5 Fan Replacement
Cosa ti serve
  1. HP EliteBook x360 830 G5 Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 Fan Replacement: passo 2, immagine 1 di 2 HP EliteBook x360 830 G5 Fan Replacement: passo 2, immagine 2 di 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 Fan Replacement: passo 3, immagine 1 di 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 Fan Replacement, Fan: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • With tweezers, pull back the retention tape that is attached to the fan cable.
  5. HP EliteBook x360 830 G5 Fan Replacement: passo 5, immagine 1 di 1
    • Use your fingers to carefully disconnect the fan cable from the motherboard.
  6. HP EliteBook x360 830 G5 Fan Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #1 screwdriver, loosen the three screws that secure the fan to the motherboard.
  7. HP EliteBook x360 830 G5 Fan Replacement: passo 7, immagine 1 di 1
    • With two fingers, carefully lift the left edge of the fan and remove it from the board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 39
Tutti i Tempi: 619
