Introduzione
This guide shows how to remove the wireless card from your laptop.
Cosa ti serve
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
