Salta al contenuto principale
HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement
Cosa ti serve
  1. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 2, immagine 1 di 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 4, immagine 1 di 2 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 4, immagine 2 di 2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 5, immagine 1 di 1
    • Gently lift the battery out of its place.
  6. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Touchpad: passo 6, immagine 1 di 2 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Touchpad: passo 6, immagine 2 di 2
    • Remove the six 1.95 mm JIS #000 screws that secure the metal frame of the touchpad.
  7. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 7, immagine 1 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 7, immagine 2 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 7, immagine 3 di 3
    • Lift the small white ZIF connector from the front using a spudger tool or your finger.
    • Only lift the white hinge securing the Flexed Flat Cable making sure the unit stays secure to the board.
  8. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 8, immagine 1 di 1
    • Pull the yellow and orange striped ribbon away.
  9. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 9, immagine 1 di 1
    • Lift the touchpad up from the computer board by the metal frame.
  10. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Speakers: passo 10, immagine 1 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Speakers: passo 10, immagine 2 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Speakers: passo 10, immagine 3 di 3
    • Remove the two 3.52 mm JIS #000 screws from the left speaker.
    • The speakers are magnetic, so carefully remove from its magnetic place.
  11. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 11, immagine 1 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 11, immagine 2 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 11, immagine 3 di 3
    • Follow the red and black wire and you will see the two wire brackets.
    • Use the spudger to slide it and push the wire out of the brackets, then take it out.
  12. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 12, immagine 1 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 12, immagine 2 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 12, immagine 3 di 3
    • Remove the two 3.52 mm JIS #000 screws from the right speaker and carefully remove from its magnetic place.
    • Remove the black tape with your hand that is around wire.
  13. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 13, immagine 1 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 13, immagine 2 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 13, immagine 3 di 3
    • Remove the black tape from the mother board with your hand.
    • Unplug the green and white wire plug gently, and the red and black wire plug gently with your hand.
  14. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Thumbprint Scanner: passo 14, immagine 1 di 2 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement, Thumbprint Scanner: passo 14, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Halberd Spudger
    $2.99
    • Use the Halberd Spudger to lift the ZIF connector tab and free the thumbprint ribbon cable.
    • Be sure not to remove the plastic hinge from the board. It only flips up to release the tape wire.
  15. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 15, immagine 1 di 1
    • Remove the two 2.39 mm JIS #000 screws in a counter-clockwise motion.
  16. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 16, immagine 1 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 16, immagine 2 di 3 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 16, immagine 3 di 3
    • Lift the metal cover, and then pull it out of its plastic bracket towards the motherboard.
  17. HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 17, immagine 1 di 2 HP EliteBook x360 1030 G3 Thumbprint Scanner Replacement: passo 17, immagine 2 di 2
    • Lift the whole component from the board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 367
