Salta al contenuto principale
HP EliteBook x360 1030 G3 Bottom Cover Replacement
Cosa ti serve
  1. HP EliteBook x360 1030 G3 Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Bottom Cover Replacement: passo 2, immagine 1 di 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S2-G9, Maness Spring 2019 Membro di Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 57
Tutti i Tempi: 6,457
