Salta al contenuto principale
HP EliteBook Folio 1020 G1 Wi-Fi Card Replacement
Cosa ti serve
  1. HP EliteBook Folio 1020 G1 Wi-Fi Card Replacement, Lower Case: passo 1, immagine 1 di 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 1 di 2 HP EliteBook Folio 1020 G1 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 2 di 2
    • Disconnect the two coaxial cables connected to the card.
    • Be sure to remember which wire is which. It is easy to get these wires mixed up.
  4. HP EliteBook Folio 1020 G1 Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew and remove the single 1.8 mm screw that secures the card to the board.
  5. HP EliteBook Folio 1020 G1 Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Lift the card slightly and then pull away from the port and remove.
Conclusione
Drew Borden
Membro da: 03/22/22
606 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 10
Tutti i Tempi: 162
