Salta al contenuto principale
HP EliteBook Folio 1020 G1 Trackpad Replacement
Cosa ti serve
  1. HP EliteBook Folio 1020 G1 Trackpad Replacement, Lower Case: passo 1, immagine 1 di 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Trackpad Replacement: passo 2, immagine 1 di 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Trackpad Replacement, Trackpad: passo 3, immagine 1 di 2 HP EliteBook Folio 1020 G1 Trackpad Replacement, Trackpad: passo 3, immagine 2 di 2
    • Unplug the white bundled cable connector that leads from the battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 Trackpad Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
  5. HP EliteBook Folio 1020 G1 Trackpad Replacement: passo 5, immagine 1 di 1
    • The trackpad is connected to the motherboard via a small ribbon cable. Lift the black tab on the ZIF cable connector, and gently pull the ribbon cable free.
  6. HP EliteBook Folio 1020 G1 Trackpad Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew and remove the four 2 mm screws that secure the trackpad.
  7. HP EliteBook Folio 1020 G1 Trackpad Replacement: passo 7, immagine 1 di 1
    • Remove the trackpad.
Conclusione
Drew Borden
Membro da: 03/22/22
606 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 34
Tutti i Tempi: 369
