Salta al contenuto principale
HP EliteBook 8560w Back Panel Replacement
Cosa ti serve
  1. HP EliteBook 8560w Back Panel Replacement, Battery: passo 1, immagine 1 di 2 HP EliteBook 8560w Back Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Back Panel Replacement: passo 2, immagine 1 di 1
    • Pull the battery out.
  3. HP EliteBook 8560w Back Panel Replacement, Back Panel: passo 3, immagine 1 di 2 HP EliteBook 8560w Back Panel Replacement, Back Panel: passo 3, immagine 2 di 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Back Panel Replacement: passo 4, immagine 1 di 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,637
