Salta al contenuto principale
HP EliteBook 8530w RAM Replacement
Cosa ti serve
  1. HP EliteBook 8530w RAM Replacement, Battery: passo 1, immagine 1 di 2 HP EliteBook 8530w RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w RAM Replacement: passo 2, immagine 1 di 2 HP EliteBook 8530w RAM Replacement: passo 2, immagine 2 di 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
  3. HP EliteBook 8530w RAM Replacement, RAM: passo 3, immagine 1 di 3 HP EliteBook 8530w RAM Replacement, RAM: passo 3, immagine 2 di 3 HP EliteBook 8530w RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Unscrew the two screws with a RAM/WiFi icon using a Phillips #00 screwdriver.
    • These screws are retained (not designed to be removed). Just loosen them.
    • After the screws are loosened, pull the cover off by lifting up from the side with the screws.
  4. HP EliteBook 8530w RAM Replacement: passo 4, immagine 1 di 3 HP EliteBook 8530w RAM Replacement: passo 4, immagine 2 di 3 HP EliteBook 8530w RAM Replacement: passo 4, immagine 3 di 3
    • Once the cover is removed, you will see two rectangular RAM sticks as shown in the picture.
    • Pull each of the tabs holding the RAM in place apart from each other.
    • Little force is required to pull the tabs. Be careful when bending them back.
    • Once the tabs are pulled away, the RAM should pop up to rest at a 45º angle to the motherboard.
  5. HP EliteBook 8530w RAM Replacement: passo 5, immagine 1 di 2 HP EliteBook 8530w RAM Replacement: passo 5, immagine 2 di 2
    • Pull the RAM out of the laptop in the direction the RAM is pointing at to remove it.
    • When inserting RAM into the laptop, make sure that when you fold the RAM down the tabs are holding it in place. You may hear a "click" from the tabs when you fold the RAM down. That means that the tabs should be holding the RAM.
Conclusione
Un commento
I just removed my 2G ram from the back as soy said but the laptop still can run.
At the slot of the ram I removed it has a number 3 and I am wondering if it is a "hidden" one?
Aggelos Printezis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 683
