Salta al contenuto principale
HP EliteBook 8530w Fan Replacement
Cosa ti serve
  1. HP EliteBook 8530w Fan Replacement, Battery: passo 1, immagine 1 di 2 HP EliteBook 8530w Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Fan Replacement: passo 2, immagine 1 di 2 HP EliteBook 8530w Fan Replacement: passo 2, immagine 2 di 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
  3. HP EliteBook 8530w Fan Replacement, Fan: passo 3, immagine 1 di 1
    • Unscrew the two screws from the center panel with a Phillips #00 screwdriver.
    • These screws should have a keyboard icon stamped next to them.
  4. HP EliteBook 8530w Fan Replacement: passo 4, immagine 1 di 3 HP EliteBook 8530w Fan Replacement: passo 4, immagine 2 di 3 HP EliteBook 8530w Fan Replacement: passo 4, immagine 3 di 3
    • Flip the laptop over then open the lid.
    • Slide the four tabs at the top of the keyboard towards you with your finger.
    • Wedge a finger or spudger in the top corner of the keyboard and hinge it forward to reveal the backside.
    • Do not try to pull the keyboard out of the laptop. There are still cables connected to it that can easily be damaged.
  5. HP EliteBook 8530w Fan Replacement: passo 5, immagine 1 di 3 HP EliteBook 8530w Fan Replacement: passo 5, immagine 2 di 3 HP EliteBook 8530w Fan Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a Torx TR7 screwdriver to remove the three screws holding down the fan.
    • Gently remove the fan connector that plugs into the motherboard.
    • Note: It can help to use something like tweezers to remove the connector if you are having trouble.
    • Remove the fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 758
