Salta al contenuto principale
HP EliteBook 8530w Battery Replacement
  1. HP EliteBook 8530w Battery Replacement, Battery: passo 1, immagine 1 di 2 HP EliteBook 8530w Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Battery Replacement: passo 2, immagine 1 di 2 HP EliteBook 8530w Battery Replacement: passo 2, immagine 2 di 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 529
