Salta al contenuto principale
HP EliteBook 850 G5 Battery Replacement
Cosa ti serve
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover screws: passo 2, immagine 1 di 1
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
  2. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover: passo 3, immagine 1 di 1
    • Starting under the middle of the display, pry and lift the bottom cover off the computer. Consider using a spudger.
  3. HP EliteBook 850 G5 Battery Replacement, Disconnect the battery: passo 4, immagine 1 di 1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  4. HP EliteBook 850 G5 Battery Replacement, Remove the battery: passo 5, immagine 1 di 1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Conclusione
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Membro da: 04/22/20
40.307 Reputazione
16 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.410 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 285
Tutti i Tempi: 5,933
