Salta al contenuto principale
HP EliteBook 840 G7 keyboard Replacement
Cosa ti serve
  1. HP EliteBook 840 G7 keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 keyboard Replacement: passo 2, immagine 1 di 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 keyboard Replacement: passo 4, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 4, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 4, immagine 3 di 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 keyboard Replacement: passo 5, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 5, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 5, immagine 3 di 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 keyboard Replacement, Display Assembly: passo 6, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement, Display Assembly: passo 6, immagine 2 di 2
    • Pull up to remove the two coaxial Wi-Fi card connectors.
  7. HP EliteBook 840 G7 keyboard Replacement: passo 7, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement: passo 7, immagine 2 di 2
    • Pull upwards on the display connector to remove.
  8. HP EliteBook 840 G7 keyboard Replacement: passo 8, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement: passo 8, immagine 2 di 2
    • Pull or push to remove the bundled cable connector.
  9. HP EliteBook 840 G7 keyboard Replacement: passo 9, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement: passo 9, immagine 2 di 2
    • Pull upwards to remove the webcam connector.
  10. HP EliteBook 840 G7 keyboard Replacement: passo 10, immagine 1 di 1
    • Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
  11. HP EliteBook 840 G7 keyboard Replacement: passo 11, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement: passo 11, immagine 2 di 2
    • Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
  12. HP EliteBook 840 G7 keyboard Replacement: passo 12, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement: passo 12, immagine 2 di 2
    • Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
  13. HP EliteBook 840 G7 keyboard Replacement: passo 13, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 13, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 13, immagine 3 di 3
    • Open the laptop to a 90 degree angle.
    • Slide the display hinges away to remove the display assembly.
  14. HP EliteBook 840 G7 keyboard Replacement, Keyboard: passo 14, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement, Keyboard: passo 14, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement, Keyboard: passo 14, immagine 3 di 3
    • Pull on the bundled connector to remove.
    • Remove the speaker system from the board.
  15. HP EliteBook 840 G7 keyboard Replacement: passo 15, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement: passo 15, immagine 2 di 2
    • Push away to remove the bundled connector from its port.
    • Move the cable away from the ZIF connector below.
  16. HP EliteBook 840 G7 keyboard Replacement: passo 16, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 16, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 16, immagine 3 di 3
    • Lift the latch on the ZIF connector.
    • Pull away on the connector to remove.
  17. HP EliteBook 840 G7 keyboard Replacement: passo 17, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 17, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 17, immagine 3 di 3
    • Use your Phillips #1 screwdriver to remove the three 1.3 mm screws.
    • Lift up and away to remove the USB ports.
  18. HP EliteBook 840 G7 keyboard Replacement: passo 18, immagine 1 di 2 HP EliteBook 840 G7 keyboard Replacement: passo 18, immagine 2 di 2
    • Push away to remove the bundled connector.
  19. HP EliteBook 840 G7 keyboard Replacement: passo 19, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 19, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 19, immagine 3 di 3
    • Use your Phillips # 1 screwdriver to remove the three 1.2 mm screws that hold the fan in place.
    • Lift up from the left side of the fan then pull towards you to remove.
  20. HP EliteBook 840 G7 keyboard Replacement: passo 20, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 20, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 20, immagine 3 di 3
    • After removing the connector pull off the CMOS battery.
  21. HP EliteBook 840 G7 keyboard Replacement: passo 21, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 21, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 21, immagine 3 di 3
    • Use your Phillips #1 screwdriver to remove the single 1.2 mm screw.
    • Pull on the cable to remove the charging port.
  22. HP EliteBook 840 G7 keyboard Replacement: passo 22, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 22, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 22, immagine 3 di 3
    • Lift on the latch on the ZIF connector.
    • Pull on the cable to remove.
  23. HP EliteBook 840 G7 keyboard Replacement: passo 23, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 23, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 23, immagine 3 di 3
    • Release the latch on the ZIF connector.
    • Carefully pull the connector to remove.
  24. HP EliteBook 840 G7 keyboard Replacement: passo 24, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 24, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 24, immagine 3 di 3
    • Use you Phillips #1 screwdriver to remove the eight 1.2 mm screws.
    • Lift the whole board up to remove.
  25. HP EliteBook 840 G7 keyboard Replacement: passo 25, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 25, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 25, immagine 3 di 3
  26. HP EliteBook 840 G7 keyboard Replacement: passo 26, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 26, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 26, immagine 3 di 3
  27. HP EliteBook 840 G7 keyboard Replacement: passo 27, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 27, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 27, immagine 3 di 3
    • Use your Phillips #000 screwdriver to remove the four 1 mm screws.
    • Pull up to remove.
    • Careful to not harm other cables.
  28. HP EliteBook 840 G7 keyboard Replacement: passo 28, immagine 1 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 28, immagine 2 di 3 HP EliteBook 840 G7 keyboard Replacement: passo 28, immagine 3 di 3
    • Use your Phillips #000 screwdriver to remove the five 1 mm screws.
    • Lift the touchpad to remove.
Conclusione
Altre 5 persone hanno completato questa guida.
Gateway, Team 1-1, Pee Spring 2022 Membro di Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Membri
5 Guide realizzate
3 Commenti
Donc ce tuto permet de tout enlever sauf le clavier?
Pilc - Replica
This is only replacement of the touchpad?
Where is the keyboard replacement?
Koehoe22 - Replica
the keyboard is part of the top shell and is rivetted in, you need to replace the whole part
Leonardo Di Stefano -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 466
Tutti i Tempi: 10,454
