Salta al contenuto principale
HP EliteBook 840 G7 Display Assembly Replacement
Cosa ti serve
  1. HP EliteBook 840 G7 Display Assembly  Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Display Assembly  Replacement: passo 2, immagine 1 di 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Display Assembly  Replacement: passo 3, immagine 1 di 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Display Assembly  Replacement: passo 4, immagine 1 di 3 HP EliteBook 840 G7 Display Assembly  Replacement: passo 4, immagine 2 di 3 HP EliteBook 840 G7 Display Assembly  Replacement: passo 4, immagine 3 di 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Display Assembly  Replacement: passo 5, immagine 1 di 3 HP EliteBook 840 G7 Display Assembly  Replacement: passo 5, immagine 2 di 3 HP EliteBook 840 G7 Display Assembly  Replacement: passo 5, immagine 3 di 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Display Assembly  Replacement, Display Assembly: passo 6, immagine 1 di 2 HP EliteBook 840 G7 Display Assembly  Replacement, Display Assembly: passo 6, immagine 2 di 2
    • Pull up to remove the two coaxial Wi-Fi card connectors.
  7. HP EliteBook 840 G7 Display Assembly  Replacement: passo 7, immagine 1 di 2 HP EliteBook 840 G7 Display Assembly  Replacement: passo 7, immagine 2 di 2
    • Pull upwards on the display connector to remove.
  8. HP EliteBook 840 G7 Display Assembly  Replacement: passo 8, immagine 1 di 2 HP EliteBook 840 G7 Display Assembly  Replacement: passo 8, immagine 2 di 2
    • Pull or push to remove the bundled cable connector.
  9. HP EliteBook 840 G7 Display Assembly  Replacement: passo 9, immagine 1 di 2 HP EliteBook 840 G7 Display Assembly  Replacement: passo 9, immagine 2 di 2
    • Pull upwards to remove the webcam connector.
  10. HP EliteBook 840 G7 Display Assembly  Replacement: passo 10, immagine 1 di 1
    • Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
  11. HP EliteBook 840 G7 Display Assembly  Replacement: passo 11, immagine 1 di 2 HP EliteBook 840 G7 Display Assembly  Replacement: passo 11, immagine 2 di 2
    • Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
  12. HP EliteBook 840 G7 Display Assembly  Replacement: passo 12, immagine 1 di 2 HP EliteBook 840 G7 Display Assembly  Replacement: passo 12, immagine 2 di 2
    • Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
  13. HP EliteBook 840 G7 Display Assembly  Replacement: passo 13, immagine 1 di 3 HP EliteBook 840 G7 Display Assembly  Replacement: passo 13, immagine 2 di 3 HP EliteBook 840 G7 Display Assembly  Replacement: passo 13, immagine 3 di 3
    • Open the laptop to a 90 degree angle.
    • Slide the display hinges away to remove the display assembly.
Linea Traguardo
Gateway, Team 1-1, Pee Spring 2022 Membro di Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 103
Tutti i Tempi: 2,521
