Salta al contenuto principale
HP EliteBook 840 G6 Disassembly
Cosa ti serve
  1. HP EliteBook 840 G6 Disassembly, Identify the screws: passo 1, immagine 1 di 1
    • Identify the screws.
  2. HP EliteBook 840 G6 Disassembly, Unscrew the screws: passo 2, immagine 1 di 2 HP EliteBook 840 G6 Disassembly, Unscrew the screws: passo 2, immagine 2 di 2
    • Unscrew the screws.
    • Screws are attached to the back panel.
  3. HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: passo 3, immagine 1 di 3 HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: passo 3, immagine 2 di 3 HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Tool
    $1.99
    • Use your fingernail or the iFixit Opening Tool.
    • Start on the far side when prying apart.
    • Open the computer.
    • The display should face the table.
    • Separate gently the back cover from the front panel (keyboard panel).
  4. HP EliteBook 840 G6 Disassembly, Open back and front cover: passo 4, immagine 1 di 3 HP EliteBook 840 G6 Disassembly, Open back and front cover: passo 4, immagine 2 di 3 HP EliteBook 840 G6 Disassembly, Open back and front cover: passo 4, immagine 3 di 3
    • Open each side gently (keyboard panel is facing up, the back cover is facing down).
    • Store the back cover.
  5. HP EliteBook 840 G6 Disassembly, End result: passo 5, immagine 1 di 1
    • You now have access to the mainboard.
Conclusione
Altre 10 persone hanno completato questa guida.
Eric M2264
Membro da: 12/27/21
596 Reputazione
2 Guide realizzate
5Commenti sulla guida
Are the 6 silver-colored screws holding the back cover on all the same length?
David Cary - Replica
All of the screws are captive, meaning they don't come out of their holes. They are not all the same length, however, but since you can't lose them you don't need to worry about getting them back into the same holes.
Tyler Regas -
The central screw has a different size.
Eric M2264 - Replica
Do you have instructions on replacing the lcd touch screen?
Frank Coheley - Replica
I have not any instructions about lcd touch screen replacement. Sorry.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 102
Ultimi 30 Giorni: 450
Tutti i Tempi: 12,723
