Salta al contenuto principale
HP EliteBook 840 G5 RAM Replacement
Cosa ti serve
  1. HP EliteBook 840 G5 RAM Replacement, Back Cover: passo 1, immagine 1 di 2 HP EliteBook 840 G5 RAM Replacement, Back Cover: passo 1, immagine 2 di 2
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 RAM Replacement: passo 2, immagine 1 di 3 HP EliteBook 840 G5 RAM Replacement: passo 2, immagine 2 di 3 HP EliteBook 840 G5 RAM Replacement: passo 2, immagine 3 di 3
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 RAM Replacement: passo 3, immagine 1 di 1
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
  4. HP EliteBook 840 G5 RAM Replacement, RAM: passo 4, immagine 1 di 2 HP EliteBook 840 G5 RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Using your fingers, remove the clips on the sides of the sticks of RAM by pulling up and towards you.
  5. HP EliteBook 840 G5 RAM Replacement: passo 5, immagine 1 di 2 HP EliteBook 840 G5 RAM Replacement: passo 5, immagine 2 di 2
    • Once the side gates are removed the stick of RAM will pop up and you can pull it out.
Conclusione
Altre 11 persone hanno completato questa guida.
Cal Poly, Team S25-G13, Maness Spring 2018 Membro di Cal Poly, Team S25-G13, Maness Spring 2018
CPSU-MANESS-S18S25G13
4 Membri
18 Guide realizzate
3 Commenti
Just FYI for anyone reading this, the pictures appear to be from an Elitebook 850 G5, not the 840. This is important because the two screws they show in the middle on either side are NOT present on the Elitebook 840 G5.
Chris - Replica
ACHTUNG ZERSTÖRUNGSGEFAHR - Die Beschreibung ist Fehlerhaf!!!
Beim 840 g5 gibt es in den beiden „oberen ecken“ 2 versenkte Schrauben die UNBEDINGT gelöst werden müssen - tut man das nicht kann man den Boden NICHT ZERSTÖRUNGSFREI abheben!!!
Außerdem gibt es die beiden „mittleren äußern“ Schrauben beim 840 g5 NICHT
Zusatz: Alle Schrauben müssen nur gelöst, nicht aber entfernt werden.
Bei dem in dieser Anleitung beschrieben Gerät handelt es sich offensichtlich um ein 850 g5…
Ossi2912 - Replica
Whats the max ram capacity ?
DARK SHADOW - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 101
Tutti i Tempi: 19,502
