Salta al contenuto principale
Sostituzione copertura posteriore HP EliteBook 840 G5
Cosa ti serve
  1. Sostituzione copertura posteriore HP EliteBook 840 G5, Copertura posteriore: passo 1, immagine 1 di 2 Sostituzione copertura posteriore HP EliteBook 840 G5, Copertura posteriore: passo 1, immagine 2 di 2
    • Usa un cacciavite a croce Phillips #1 per svitare cinque viti. Le tre più in alto sono da 10 mm, mentre le due ai lati sono da 7 mm.
    • Svita le tre viti inferiori con lo stesso cacciavite.
    • Le viti a croce Phillips #1 non verranno rimosse dalla copertura, ma devono essere svitate.
    • Alcuni modelli hanno una posizione delle viti leggermente diversa, mostrata nella seconda immagine.
    On my HP EliteBook 840 G5, the “two side screws” (black) are found inside the two holes seen next to the left top screw, and between the center and right top screw.
    Ruedi Port - Replica
    Mine had the same, and these black screws also need to be released in order to remove the bottom panel.
    Josh -
    Correct. Some other models have 2 black screws at the back, near the corners.
    The models with the 2 black screws, are missing the 2 silver screws at the left side and the right side in the middle.
    Note: You need to release the 2 black screws as well, if your type of model has them.
    koppie007 - Replica
    Thank you this was very helpful. I was able to remove the cover and the SSD.
    Stupid question but is this board considered the hard drive? my laptop failed (no power) and I did get an identical replacement. In the past I have been able to remove the hard drive in the failed laptop and connect it to the new one via a data transfer cable (removed hard drive to usb in new laptop. I could then browse files off of the old hard drive and transfer them over to the new. This SSD board has vastly different connectors. Do you know if they make a transfer cable that connects to this board with a usb on the other end?
    dgtuk1 - Replica
    I removed the back cover and installed a new SSD. When I went to put the back cover, the center screw would not go back in. It turns but does not catch. Any advice?
    Erik - Replica
  2. Sostituzione copertura posteriore HP EliteBook 840 G5: passo 2, immagine 1 di 3 Sostituzione copertura posteriore HP EliteBook 840 G5: passo 2, immagine 2 di 3 Sostituzione copertura posteriore HP EliteBook 840 G5: passo 2, immagine 3 di 3
    • Ruota il portatile in mdo che la cerniera sia rivolta verso l'alto.
    • Usa uno strumento di apertura in plastica per aprire la copertura posteriore.
    • Fai scorrere lo strumento di apertura in plastica lungo il bordo da sinistra a destra e usa un secondo strumento di apertura per fare leva sull'angolo in alto a destra.
    • Ripeti il passaggio precedente anche per l'altro angolo.
    • Ripeti la procedura anche per i lati sinistro e destro del portatile. C'è un punto al centro di ognuno di questi lati (vicino alle viti che hai rimossi all'inizio) che dovrai rilasciare facendo una leggera forza.
    • Dovresti sentire un suono secco quando sganci gli angoli.
  3. Sostituzione copertura posteriore HP EliteBook 840 G5: passo 3, immagine 1 di 1
    • Prendi la copertura posteriore e sollevala lentamente dal dispositivo.
    • Non ci sono cavi collegati alla copertura posteriore. Separala comunque prestando attenzione: ci sono delle componenti elettrice nelle vicinanze.
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso. Questa procedura è importante, in quanto è il primo passaggio di tutte le guide per accedere alle componenti interne del computer.
Altre 6 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Cal Poly, Team S25-G13, Maness Spring 2018 Membro di Cal Poly, Team S25-G13, Maness Spring 2018
CPSU-MANESS-S18S25G13
4 Membri
18 Guide realizzate
2 Commenti
vous auriez le numero de piece a commander , je ne le trouve nul part
F H - Replica
Thank you so much for this tutorial! I was able to remove my bloated battery and replace it without taking the notebook into a repair shop. I ordered the screwdrivers on Amazon and my new battery and the screwdrivers arrived today. Job done! :)
Fiona Fars - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 57
Ultimi 30 Giorni: 228
Tutti i Tempi: 27,358
