Salta al contenuto principale
HP EliteBook 745 G4 Battery Replacement
Cosa ti serve
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: passo 2, immagine 1 di 1
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: passo 3, immagine 1 di 2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: passo 3, immagine 2 di 2
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: passo 4, immagine 1 di 1
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: passo 5, immagine 1 di 1
    • Loosen the two captive screws and remove the battery from the computer
Conclusione
To replace the battery & reassemble your device, follow these instructions in reverse order.
Altre 4 persone hanno completato questa guida.
Max Kletskov
Membro da: 04/22/20
40.880 Reputazione
16 Guide realizzate
The Home Depot Membro di The Home Depot
Community
18.099 Membri
141 Guide realizzate
2 Commenti
you forgot to put the instructions for after the battery is installed when you boot it up You’ll get non-HP battery detected asking you to press enter on every boot. How is this problem fixed?
Richard B - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 45
Tutti i Tempi: 1,683
