Salta al contenuto principale
HP EliteBook 745 G2 Battery Replacement
Cosa ti serve
  1. HP EliteBook 745 G2 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 Battery Replacement: passo 2, immagine 1 di 2 HP EliteBook 745 G2 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 Battery Replacement: passo 3, immagine 1 di 2 HP EliteBook 745 G2 Battery Replacement: passo 3, immagine 2 di 2
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,055
