Salta al contenuto principale
HP EliteBook 1050 G1 SSD Replacement
Cosa ti serve
  1. HP EliteBook 1050 G1 SSD Replacement, SSD: passo 1, immagine 1 di 2 HP EliteBook 1050 G1 SSD Replacement, SSD: passo 1, immagine 2 di 2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 SSD Replacement: passo 2, immagine 1 di 1
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
  3. HP EliteBook 1050 G1 SSD Replacement: passo 3, immagine 1 di 2 HP EliteBook 1050 G1 SSD Replacement: passo 3, immagine 2 di 2
    • With the screws removed, the SSD should pop up off of the board below.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
    • When re-inserting the new SSDs make sure the white specs labels are facing up.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 813
