Salta al contenuto principale
HP EliteBook 1050 G1 RAM Replacement
Cosa ti serve
  1. HP EliteBook 1050 G1 RAM Replacement, RAM: passo 1, immagine 1 di 2 HP EliteBook 1050 G1 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Lift open the back panel with a Jimmy.
  2. HP EliteBook 1050 G1 RAM Replacement: passo 2, immagine 1 di 3 HP EliteBook 1050 G1 RAM Replacement: passo 2, immagine 2 di 3 HP EliteBook 1050 G1 RAM Replacement: passo 2, immagine 3 di 3
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 329
