Salta al contenuto principale
HP EliteBook 1040 G4 Trackpad Replacement
Cosa ti serve
  1. HP EliteBook 1040 G4 Trackpad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Trackpad Replacement: passo 2, immagine 1 di 2 HP EliteBook 1040 G4 Trackpad Replacement: passo 2, immagine 2 di 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Trackpad Replacement, Battery: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Trackpad Replacement: passo 4, immagine 1 di 2 HP EliteBook 1040 G4 Trackpad Replacement: passo 4, immagine 2 di 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Trackpad Replacement: passo 5, immagine 1 di 2 HP EliteBook 1040 G4 Trackpad Replacement: passo 5, immagine 2 di 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Trackpad Replacement, Trackpad: passo 6, immagine 1 di 1
    • Peel back the foam cover to reveal the underside of the trackpad.
  7. HP EliteBook 1040 G4 Trackpad Replacement: passo 7, immagine 1 di 1
    • Carefully disconnect the white ribbon cable attached to the underside of the trackpad.
  8. HP EliteBook 1040 G4 Trackpad Replacement: passo 8, immagine 1 di 1
    • Carefully disconnect the black ribbon cable attached to the chassis.
  9. HP EliteBook 1040 G4 Trackpad Replacement: passo 9, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws securing the trackpad.
  10. HP EliteBook 1040 G4 Trackpad Replacement: passo 10, immagine 1 di 1
    • Lift and remove the trackpad from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 431
