Salta al contenuto principale
HP EliteBook 1040 G4 Speakers Replacement
Cosa ti serve
  1. HP EliteBook 1040 G4 Speakers Replacement, Back Cover: passo 1, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Speakers Replacement: passo 2, immagine 1 di 2 HP EliteBook 1040 G4 Speakers Replacement: passo 2, immagine 2 di 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Speakers Replacement, Battery: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Speakers Replacement: passo 4, immagine 1 di 2 HP EliteBook 1040 G4 Speakers Replacement: passo 4, immagine 2 di 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Speakers Replacement: passo 5, immagine 1 di 2 HP EliteBook 1040 G4 Speakers Replacement: passo 5, immagine 2 di 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Speakers Replacement, Speakers: passo 6, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the four black 6 mm screws securing the speakers to the device.
  7. HP EliteBook 1040 G4 Speakers Replacement: passo 7, immagine 1 di 1
    • Disconnect the pin connector from the right side of the speaker assembly.
  8. HP EliteBook 1040 G4 Speakers Replacement: passo 8, immagine 1 di 1
    • Carefully remove the red and black wires from the black clips in between the two speakers.
  9. HP EliteBook 1040 G4 Speakers Replacement: passo 9, immagine 1 di 1
    • Remove the speakers from the device.
Conclusione
Clemson, Team 4-1, Hunter Fall 2021 Membro di Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 632
