Introduzione
Use this guide to replace the coin cell battery on the HP Elitebook 1040 G4. The coin cell battery is essential in laptops to retain certain system settings, such as date and time, while the device is powered off. If you are experiencing problems regarding the time settings or other internal system settings, you may need to replace the coin cell battery.
To complete this guide, you will need a T5 Torx head screwdriver and a Phillips #1 and #00 screwdriver.
Before beginning, be sure to completely power off and unplug your computer.
Cosa ti serve
Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
Carefully disconnect the pin connector from the right side of the speaker assembly.
