Salta al contenuto principale
HP Elite x2 G4 Battery Replacement
Cosa ti serve
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: passo 1, immagine 1 di 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: passo 2, immagine 1 di 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Battery Replacement: passo 3, immagine 1 di 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: passo 7, immagine 1 di 1
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: passo 8, immagine 1 di 1
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
Conclusione
Goncalo Felix
Membro da: 10/25/22
325 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 144
Tutti i Tempi: 1,268
