Salta al contenuto principale
HP Elite x2 G1 1012 Rear Facing Camera Replacement
Cosa ti serve
  1. HP Elite x2 G1 1012 Rear Facing Camera Replacement, Display: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 2, immagine 1 di 2 HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 2, immagine 2 di 2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 3, immagine 1 di 1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 4, immagine 1 di 2 HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 4, immagine 2 di 2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 5, immagine 1 di 3 HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 5, immagine 2 di 3 HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 5, immagine 3 di 3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 6, immagine 1 di 2 HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 6, immagine 2 di 2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
  7. HP Elite x2 G1 1012 Rear Facing Camera Replacement, Rear Facing Camera: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to remove the flex cable on the top of the camera.
  8. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the screw in the corner of the camera.
  9. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 9, immagine 1 di 1
    • Use a spudger to delicately lift up the camera.
  10. HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 10, immagine 1 di 2 HP Elite x2 G1 1012 Rear Facing Camera Replacement: passo 10, immagine 2 di 2
    • Use a pair of tweezers to disconnect the flex cable from the motherboard and remove the rear facing camera from the device.
Conclusione
Colin Mika
Membro da: 04/19/18
943 Reputazione
6 Guide realizzate
Cal Poly, Team S24-G7, Maness Spring 2018 Membro di Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 566
