Salta al contenuto principale
HP Elite x2 G1 1012 Display Replacement
Cosa ti serve
  1. HP Elite x2 G1 1012 Display Replacement, Display: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Display Replacement: passo 2, immagine 1 di 2 HP Elite x2 G1 1012 Display Replacement: passo 2, immagine 2 di 2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Display Replacement: passo 3, immagine 1 di 1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Display Replacement: passo 4, immagine 1 di 2 HP Elite x2 G1 1012 Display Replacement: passo 4, immagine 2 di 2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Display Replacement: passo 5, immagine 1 di 3 HP Elite x2 G1 1012 Display Replacement: passo 5, immagine 2 di 3 HP Elite x2 G1 1012 Display Replacement: passo 5, immagine 3 di 3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Display Replacement: passo 6, immagine 1 di 2 HP Elite x2 G1 1012 Display Replacement: passo 6, immagine 2 di 2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
Conclusione
Altre 4 persone hanno completato questa guida.
Colin Mika
Membro da: 04/19/18
943 Reputazione
6 Guide realizzate
Cal Poly, Team S24-G7, Maness Spring 2018 Membro di Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,335
