Salta al contenuto principale
HP Elite x2 1012 G2 Screen Replacement
Cosa ti serve
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: passo 2, immagine 1 di 3 HP Elite x2 1012 G2 Screen Replacement: passo 2, immagine 2 di 3 HP Elite x2 1012 G2 Screen Replacement: passo 2, immagine 3 di 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: passo 3, immagine 1 di 2 HP Elite x2 1012 G2 Screen Replacement: passo 3, immagine 2 di 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Screen Replacement: passo 4, immagine 1 di 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: passo 5, immagine 1 di 3 HP Elite x2 1012 G2 Screen Replacement: passo 5, immagine 2 di 3 HP Elite x2 1012 G2 Screen Replacement: passo 5, immagine 3 di 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: passo 6, immagine 1 di 2 HP Elite x2 1012 G2 Screen Replacement: passo 6, immagine 2 di 2
    • Remove the screen by gently lifting it off of the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Noah Stapp
Membro da: 04/18/18
731 Reputazione
2 Guide realizzate
Cal Poly, Team S18-G5, Livingston Spring 2018 Membro di Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 Membri
13 Guide realizzate
5 Commenti
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - Replica
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - Replica
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - Replica
The touch stopped working after the replacement. Any suggestions?
el._.msn - Replica
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 119
Tutti i Tempi: 8,398
