Salta al contenuto principale
HP Elite x2 1012 G2 SSD Replacement
Cosa ti serve
  1. HP Elite x2 1012 G2 SSD Replacement, Screen: passo 1, immagine 1 di 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 SSD Replacement: passo 2, immagine 1 di 3 HP Elite x2 1012 G2 SSD Replacement: passo 2, immagine 2 di 3 HP Elite x2 1012 G2 SSD Replacement: passo 2, immagine 3 di 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 SSD Replacement: passo 3, immagine 1 di 2 HP Elite x2 1012 G2 SSD Replacement: passo 3, immagine 2 di 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 SSD Replacement: passo 4, immagine 1 di 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 SSD Replacement: passo 5, immagine 1 di 3 HP Elite x2 1012 G2 SSD Replacement: passo 5, immagine 2 di 3 HP Elite x2 1012 G2 SSD Replacement: passo 5, immagine 3 di 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 SSD Replacement: passo 6, immagine 1 di 2 HP Elite x2 1012 G2 SSD Replacement: passo 6, immagine 2 di 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 SSD Replacement, SSD: passo 7, immagine 1 di 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 SSD Replacement: passo 8, immagine 1 di 2 HP Elite x2 1012 G2 SSD Replacement: passo 8, immagine 2 di 2
    • Remove the single Phillips M2.0x2.0 screw on the SSD using a Phillips screwdriver. Turn the screwdriver counterclockwise to remove the screw.
  9. HP Elite x2 1012 G2 SSD Replacement: passo 9, immagine 1 di 2 HP Elite x2 1012 G2 SSD Replacement: passo 9, immagine 2 di 2
    • Gently pull the SSD to the left and up to remove it from the device.
Conclusione
Altre 13 persone hanno completato questa guida.
Hunter Lane
Membro da: 04/18/18
297 Reputazione
1 Guida realizzata
Cal Poly, Team S18-G5, Livingston Spring 2018 Membro di Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 Membri
13 Guide realizzate
2Commenti sulla guida
Vielen Dank für die sehr gute Anleitung. Es hat alles perfekt geklappt.
Das Display selber sitzt zum Teil aber sehr fest im Gehäuse und man muss sich überwinden etwas Kraft anzuwenden.
Sollte man zu fest ziehen (und einem das Display entgegenspringt) besteht ja die Gefahr die filigranen Kabel abzureißen.
Andreas Gerl - Replica
Mein Lüfter läuft ständig. Sollte die Wärmeleitpaste eingetrocknet sein?
Der Experte - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 201
Tutti i Tempi: 23,815
