Salta al contenuto principale
HP Elite x2 1012 G2 Cooling Fan Replacement
Cosa ti serve
  1. HP Elite x2 1012 G2 Cooling Fan Replacement, Screen: passo 1, immagine 1 di 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 2, immagine 1 di 3 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 2, immagine 2 di 3 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 3, immagine 1 di 2 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 5, immagine 1 di 3 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 5, immagine 2 di 3 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 6, immagine 1 di 2 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 6, immagine 2 di 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Cooling Fan Replacement, Battery: passo 7, immagine 1 di 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 8, immagine 1 di 2 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 8, immagine 2 di 2
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 9, immagine 1 di 2 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 9, immagine 2 di 2
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 10, immagine 1 di 1
    • Lift the battery out of the device.
  11. HP Elite x2 1012 G2 Cooling Fan Replacement, Cooling Fan: passo 11, immagine 1 di 1
    • Use the spudger tools to lift the copper tape and expose the screws.
  12. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 12, immagine 1 di 2 HP Elite x2 1012 G2 Cooling Fan Replacement: passo 12, immagine 2 di 2
    • Use Phillips #00 screwdriver to remove seven 3 mm screws.
  13. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 13, immagine 1 di 1
    • Lift the heatsink off the motherboard.
  14. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 14, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
  15. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 15, immagine 1 di 1
    • Use a spudger to lift the fan from the main unit.
  16. HP Elite x2 1012 G2 Cooling Fan Replacement: passo 16, immagine 1 di 1
    • Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S13-G13, Wilson Spring 2019 Membro di IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 58
Tutti i Tempi: 2,395
