Salta al contenuto principale
HP Elite X2 1013 G3 Fingerprint Scanner Replacement
Cosa ti serve
  1. HP Elite X2 1013 G3 Fingerprint Scanner Replacement, Screen: passo 1, immagine 1 di 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 2, immagine 1 di 2 HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 2, immagine 2 di 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 3, immagine 1 di 2 HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 3, immagine 2 di 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 4, immagine 1 di 2 HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 4, immagine 2 di 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Fingerprint Scanner Replacement, Battery: passo 5, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 6, immagine 1 di 1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Fingerprint Scanner Replacement, Fingerprint Scanner: passo 7, immagine 1 di 1
    • Disconnect the connector from the motherboard with your fingers.
    • The screwdriver is only used as a pointing device. Never attempt to use a screwdriver to pry components apart.
  8. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 8, immagine 1 di 1
    • Remove the two speaker/antenna module mounting 2mm screws using a Phillips #00 Screwdriver.
  9. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 9, immagine 1 di 2 HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 9, immagine 2 di 2
    • Use a spudger to gently pry the left black plastic speaker/antenna module off of the frame as pictured. Start by lifting up the right side of the module, then slowly work your way down the module towards the right.
    • The slight cracking sound you will hear is the sounds of plastic clasps.
    • We removed other peripherals from the frame so we could move the speaker/antenna module completely out of the way for photographing. You should not have to do this to replace just the fingerprint scanner.
  10. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 10, immagine 1 di 2 HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 10, immagine 2 di 2
    • Remove the 2mm bracket mounting screw from the frame using a Phillips #00 Screwdriver.
    • Lift up the bracket and set aside.
  11. HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 11, immagine 1 di 3 HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 11, immagine 2 di 3 HP Elite X2 1013 G3 Fingerprint Scanner Replacement: passo 11, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Open the ribbon cable clamp and pull the cable out.
    • You may require tweezers to slide the ribbon cable out of the clamp.
    • Lift out the fingerprint scanner.
Conclusione
Cal Poly, Team S9-G12, Maness Spring 2019 Membro di Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,065
