Introduzione
The RAM is very accessible on this device so removing the back cover is your biggest hurdle. Use the plastic opening tool as often as possible and everything should be fine. Good Luck!
Cosa ti serve
Pull apart the white tabs on the outside to release the RAM module.
Gently remove the RAM module from the slot.
Altre 2 persone hanno completato questa guida.
