Salta al contenuto principale
HP ENVY 5530 Paper Path Cover Replacement
  1. HP ENVY 5530 Paper Path Cover Replacement, Paper Path Cover: passo 1, immagine 1 di 1
    • Locate the paper cover.
  2. HP ENVY 5530 Paper Path Cover Replacement: passo 2, immagine 1 di 3 HP ENVY 5530 Paper Path Cover Replacement: passo 2, immagine 2 di 3 HP ENVY 5530 Paper Path Cover Replacement: passo 2, immagine 3 di 3
    • Push the two grey connectors together
    • Lift up to remove paper path cover.
Conclusione
USF Tampa, Team 4-6, Meier Fall 2015 Membro di USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Membri
18 Guide realizzate
2 Commenti
The problem, though, is in the precise alignment of the cover when squeezing the connectors. If not done
precisely, the cover will not seat properly and printing cannot be resumed.
marylandcatdad - Replica
do you know where i could buy just the paper path cover?
Qamar Mohamoud - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,672
