Introduzione
Gear allows the scanner arm to follow the grain track and scan the document. Before replacing the gear make sure the printer is unplugged.
Cosa ti serve
Unscrew and remove the center 13mm T10 Torx Security screw using the iFixit screwdriver
Unscrew and remove the top right 13mm T10 Torx Security screw using the iFixit screwdriver
Unscrew and remove the bottom left 13mm T10 Torx Security screw using the iFixit screwdriver
