Salta al contenuto principale
HP ENVY 5530 Front Panel Replacement
Cosa ti serve
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: passo 1, immagine 1 di 1
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: passo 2, immagine 1 di 3 HP ENVY 5530 Front Panel Replacement: passo 2, immagine 2 di 3 HP ENVY 5530 Front Panel Replacement: passo 2, immagine 3 di 3
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
  3. HP ENVY 5530 Front Panel Replacement: passo 3, immagine 1 di 2 HP ENVY 5530 Front Panel Replacement: passo 3, immagine 2 di 2
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
Conclusione
USF Tampa, Team 4-6, Meier Fall 2015 Membro di USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Membri
18 Guide realizzate
4 Commenti
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - Replica
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - Replica
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - Replica
Where does the cable go?
Victorian Lover - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,990
