Salta al contenuto principale
HP Deskjet D1660 Gear Guard Replacement
Cosa ti serve
  1. HP Deskjet D1660 Gear Guard Replacement, Top Cover: passo 1, immagine 1 di 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Gear Guard Replacement: passo 2, immagine 1 di 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Gear Guard Replacement: passo 3, immagine 1 di 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Gear Guard Replacement: passo 4, immagine 1 di 3 HP Deskjet D1660 Gear Guard Replacement: passo 4, immagine 2 di 3 HP Deskjet D1660 Gear Guard Replacement: passo 4, immagine 3 di 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: passo 5, immagine 1 di 2 HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: passo 5, immagine 2 di 2
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Gear Guard Replacement: passo 6, immagine 1 di 2 HP Deskjet D1660 Gear Guard Replacement: passo 6, immagine 2 di 2
    • Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer.
    • Now detach the white strip and wires by gently lifting them up.
  7. HP Deskjet D1660 Gear Guard Replacement, Gear Guard: passo 7, immagine 1 di 1
    • The gear guard will be located on the left side of the printer.
    • Grab the plastic guard and lift it up.
Conclusione
Cal Poly, Team 1-41, Maness Winter 2014 Membro di Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,167
