Salta al contenuto principale
HP Deskjet 3522 Ink Cartridge Replacement
  1. HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: passo 1, immagine 1 di 2 HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: passo 1, immagine 2 di 2
    • Power printer on.
    • Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
  2. HP Deskjet 3522 Ink Cartridge Replacement: passo 2, immagine 1 di 2 HP Deskjet 3522 Ink Cartridge Replacement: passo 2, immagine 2 di 2
    • Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
  3. HP Deskjet 3522 Ink Cartridge Replacement: passo 3, immagine 1 di 1
    • Make sure you have the correct model number of ink that needs to be replaced.
    • For the HP Deskjet 3522 the required ink is HP 564 (Regular or XL)
  4. HP Deskjet 3522 Ink Cartridge Replacement: passo 4, immagine 1 di 2 HP Deskjet 3522 Ink Cartridge Replacement: passo 4, immagine 2 di 2
    • Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click.
    • Close the lid and allow the printer to recalibrate itself.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 1-30, Donnelly Fall 2014 Membro di USF Tampa, Team 1-30, Donnelly Fall 2014
USFT-DONNELLY-F14S1G30
1 Membro
2 Guide realizzate
Un commento
These instructions were perfect to follow and complete.
walterawa1862 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,474
