Salta al contenuto principale
HP Deskjet 2624 Scanner Glass Replacement
Cosa ti serve
  1. HP Deskjet 2624 Scanner Glass Replacement, Scanner Glass: passo 1, immagine 1 di 1
    • Unplug all cords from the printer, and remove all the paper from the tray.
  2. HP Deskjet 2624 Scanner Glass Replacement: passo 2, immagine 1 di 2 HP Deskjet 2624 Scanner Glass Replacement: passo 2, immagine 2 di 2
    • Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
  3. HP Deskjet 2624 Scanner Glass Replacement: passo 3, immagine 1 di 1
    • Gently pry the scanner bed cover slightly off of the printer at the hinge.
    • Lifting the scanning bed cover to a 45 degree angle may make it easier to remove.
  4. HP Deskjet 2624 Scanner Glass Replacement: passo 4, immagine 1 di 1
    • Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
    • Set the printer body aside.
  5. HP Deskjet 2624 Scanner Glass Replacement: passo 5, immagine 1 di 3 HP Deskjet 2624 Scanner Glass Replacement: passo 5, immagine 2 di 3 HP Deskjet 2624 Scanner Glass Replacement: passo 5, immagine 3 di 3
    • Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
    • Pull the halves apart while undoing the clips to prevent plastic snapping.
  6. HP Deskjet 2624 Scanner Glass Replacement: passo 6, immagine 1 di 2 HP Deskjet 2624 Scanner Glass Replacement: passo 6, immagine 2 di 2
    • Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
    • Glass edges can be sharp, handle glass and glass shards with gloves.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 763
