Salta al contenuto principale
HP Deskjet 2624 Motherboard Replacement
Cosa ti serve
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: passo 2, immagine 1 di 2 HP Deskjet 2624 Motherboard Replacement: passo 2, immagine 2 di 2
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: passo 3, immagine 1 di 2 HP Deskjet 2624 Motherboard Replacement: passo 3, immagine 2 di 2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 545
