Salta al contenuto principale
HP Deskjet 2624 Magnetic Strip Replacement
Cosa ti serve
  1. HP Deskjet 2624 Magnetic Strip Replacement, Magnetic Strip: passo 1, immagine 1 di 1
    • Unplug the printer and remove all paper from the input tray.
  2. HP Deskjet 2624 Magnetic Strip Replacement: passo 2, immagine 1 di 2 HP Deskjet 2624 Magnetic Strip Replacement: passo 2, immagine 2 di 2
    • Using the Torx T5 screwdriver, remove the four screws holding the scanner bed module to the printer base.
    • Slowly lift up the scanner bed slightly off the base.
    • Be sure to unplug the ribbons connecting the two parts by pulling them straight out of their plugs gently.
  3. HP Deskjet 2624 Magnetic Strip Replacement: passo 3, immagine 1 di 2 HP Deskjet 2624 Magnetic Strip Replacement: passo 3, immagine 2 di 2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Magnetic Strip Replacement: passo 4, immagine 1 di 3 HP Deskjet 2624 Magnetic Strip Replacement: passo 4, immagine 2 di 3 HP Deskjet 2624 Magnetic Strip Replacement: passo 4, immagine 3 di 3
    • Locate the magnetic strip found running straight through the ink cartridge carriage.
  5. HP Deskjet 2624 Magnetic Strip Replacement: passo 5, immagine 1 di 3 HP Deskjet 2624 Magnetic Strip Replacement: passo 5, immagine 2 di 3 HP Deskjet 2624 Magnetic Strip Replacement: passo 5, immagine 3 di 3
    • To remove the strip, start by applying pressure to the silver connection located on the right hand side of the strip.
    • While applying pressure to the right hand side, push the strip off the left hand hook and pull it straight up.
    • Lift the strip vertically and unhook it from the silver strip.
    • When putting the strip back in, ensure that the arrow on the replacement faces to the right and downwards.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 514
