Salta al contenuto principale
HP Deskjet 2624 Ink Cartridges Replacement
  1. HP Deskjet 2624 Ink Cartridges Replacement, Ink Cartridges: passo 1, immagine 1 di 1
    • Unplug all of the cords from the printer and put paper into the input tray.
  2. HP Deskjet 2624 Ink Cartridges Replacement: passo 2, immagine 1 di 3 HP Deskjet 2624 Ink Cartridges Replacement: passo 2, immagine 2 di 3 HP Deskjet 2624 Ink Cartridges Replacement: passo 2, immagine 3 di 3
    • Lower the output tray and the ink cartridge access door.
    • Lightly press forward on the cartridge to release it and then pull the cartridge straight out.
    • The slot on the left is the tri-color cartridge while the black cartridge is on the right.
  3. HP Deskjet 2624 Ink Cartridges Replacement: passo 3, immagine 1 di 3 HP Deskjet 2624 Ink Cartridges Replacement: passo 3, immagine 2 di 3 HP Deskjet 2624 Ink Cartridges Replacement: passo 3, immagine 3 di 3
    • On the new cartridge, pull the colored tab to remove the plastic.
    • Hold the replacement with the nozzles toward the printer and insert it at an upward angle.
    • Push the cartridge forward until it snaps into place.
    • Repeat steps two and three if necessary.
Conclusione
After completing this guide, don’t forget to plug in your HP Deskjet 2624 .
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,216
