Salta al contenuto principale
HP Deskjet 1055 Scanner Glass Pane Replacement
Cosa ti serve
  1. HP Deskjet 1055 Scanner Glass Pane Replacement, Scanner Glass Pane: passo 1, immagine 1 di 1
    • Take all paper out of the paper tray. Unplug the printer.
    • Remove the plastic printer-control panel on the top left.
    • Then, forcefully lift up the bottom of the panel while applying downward pressure with your thumb-as shown.
  2. HP Deskjet 1055 Scanner Glass Pane Replacement: passo 2, immagine 1 di 2 HP Deskjet 1055 Scanner Glass Pane Replacement: passo 2, immagine 2 di 2
    • With your other hand, slide the top of the panel towards the back of the printer.
    • Do not rip the white cable that connects the panel with the main body of the printer.
    • Disconnect the ribbon by pinching the blue tab and pulling away from the green circuit board.
    • Lift the panel free and set to the side.
  3. HP Deskjet 1055 Scanner Glass Pane Replacement: passo 3, immagine 1 di 1
    • Place the plastic opening tool between the plastic cover and the mount on the printer.
    • Pry the plastic cover towards the center of the printer.
    • Pull up on the cover to remove it from the printer-as shown.
    • Repeat the process on the other side.
  4. HP Deskjet 1055 Scanner Glass Pane Replacement: passo 4, immagine 1 di 1
    • To remove the glass panel, take out the four 14 mm (1/2 inch) screws with a T10 Torx screwdriver.
    • Don't lift the glass panel completely off because there are cables plugged into the underside.
  5. HP Deskjet 1055 Scanner Glass Pane Replacement: passo 5, immagine 1 di 3 HP Deskjet 1055 Scanner Glass Pane Replacement: passo 5, immagine 2 di 3 HP Deskjet 1055 Scanner Glass Pane Replacement: passo 5, immagine 3 di 3
    • Disconnect the white cables from the green motherboard by pinching the cable where it connects to the green motherboard. Pull up, lightly.
    • Set the lower part of the printer aside.
  6. HP Deskjet 1055 Scanner Glass Pane Replacement: passo 6, immagine 1 di 2 HP Deskjet 1055 Scanner Glass Pane Replacement: passo 6, immagine 2 di 2
    • Place the glass panel, face down, on a smooth surface.
    • Remove the 14 mm (1/2 in.) screw from the white plastic tab on the side of the panel with a T10 Torx screwdriver.
  7. HP Deskjet 1055 Scanner Glass Pane Replacement: passo 7, immagine 1 di 3 HP Deskjet 1055 Scanner Glass Pane Replacement: passo 7, immagine 2 di 3 HP Deskjet 1055 Scanner Glass Pane Replacement: passo 7, immagine 3 di 3
    • Remove the glass pane by carefully bending the plastic frame down from the side and sliding the glass pane out from the side.
Conclusione
Cal Poly, Team 9-18, Amido Fall 2012 Membro di Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Membri
10 Guide realizzate
1Commento della guida
Which dimensions is the glass pane?
123 l - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 32
Tutti i Tempi: 4,348
