Salta al contenuto principale
HP Deskjet 1055 Motherboard Replacement
Cosa ti serve
  1. HP Deskjet 1055 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 HP Deskjet 1055 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 HP Deskjet 1055 Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Turn off the printer then open the top lid in order to see the inside of the printer.
    • Wait at least 15 minutes after turning off the printer before handling the motherboard.
    • After waiting 15 minutes, locate the blue tabs and gently pull them out of their sockets.
  2. HP Deskjet 1055 Motherboard Replacement: passo 2, immagine 1 di 1
    • Locate the three white plugs with wires attached to them. Gently grab the sides of the white chorded plugs and pull them out of their socket.
  3. HP Deskjet 1055 Motherboard Replacement: passo 3, immagine 1 di 2 HP Deskjet 1055 Motherboard Replacement: passo 3, immagine 2 di 2
    • Using a T-10 Torx screwdriver, unscrew the three 1/2'' screws on the motherboard.
    • Note which screws were taken out of their specific spot because they must me placed back to their original spot.
  4. HP Deskjet 1055 Motherboard Replacement: passo 4, immagine 1 di 1
    • Carefully pull the motherboard out of the printer.
Conclusione
In order to reassemble your device, follow these instructions in reverse orders
Altre 7 persone hanno completato questa guida.
Daniel
Membro da: 10/06/12
314 Reputazione
2 Guide realizzate
Cal Poly, Team 9-18, Amido Fall 2012 Membro di Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Membri
10 Guide realizzate
Un commento
How to open Top part
sunny.2600 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,243
