Introduzione
The one and only button on the HP Deskjet 1000 is the power button. If the power button is broken, you will be unable to turn the machine on. This guide will show you how to remove the button and then how to replace it.
Cosa ti serve
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
Carefully hold the small clip back to release the button arm.
Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot.
Replace the old power button with a new one.
