Salta al contenuto principale
HP Compaq nc8430 Battery Replacement
  1. HP Compaq nc8430 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 Battery Replacement: passo 2, immagine 1 di 1
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 Battery Replacement: passo 3, immagine 1 di 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
Conclusione
Karen Gandara
Membro da: 03/20/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 678
