Salta al contenuto principale
HP Compaq Presario cq62-214nr Motherboard Replacement
Cosa ti serve
  1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  2. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 2, immagine 1 di 2 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 2, immagine 2 di 2
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  3. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 3, immagine 1 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 3, immagine 2 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 3, immagine 3 di 3
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  4. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  5. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 5, immagine 1 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 5, immagine 2 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 5, immagine 3 di 3
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
  6. HP Compaq Presario cq62-214nr Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
  7. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 7, immagine 1 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 7, immagine 2 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 7, immagine 3 di 3
    • Locate the three tab holding down the cover of the Motherboard.
    • Lift the tabs with using either a plastic opening tool or your fingers.
  8. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 8, immagine 1 di 2 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool to lift the sides of the cover.
  9. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 9, immagine 1 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 9, immagine 2 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 9, immagine 3 di 3
    • Use your hands to gently lift the cover off.
  10. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 10, immagine 1 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 10, immagine 2 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 10, immagine 3 di 3
    • Locate the four cables securing the Motherboard.
    • Gently pull cables to unsecure them.
  11. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 11, immagine 1 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 11, immagine 2 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 11, immagine 3 di 3
    • Remove the three M2.25x5 mm Phillips screws.
  12. HP Compaq Presario cq62-214nr Motherboard Replacement: passo 12, immagine 1 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 12, immagine 2 di 3 HP Compaq Presario cq62-214nr Motherboard Replacement: passo 12, immagine 3 di 3
    • Unlatch the final cable and gently remove the Motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 2-6, Sullivan Fall 2016 Membro di USF Tampa, Team 2-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,102
