Salta al contenuto principale
HP Compaq Presario V6000 Wifi antenna card Replacement
Cosa ti serve
  1. HP Compaq Presario V6000 Wifi antenna card Replacement, Wifi antenna card: passo 1, immagine 1 di 1
    • Grab a Type-Cross #1 screwdriver and unscrew the 3 screws and take off the cover of the wifi antenna card.
  2. HP Compaq Presario V6000 Wifi antenna card Replacement: passo 2, immagine 1 di 1
    • Use your finger tips to pry off the gray antenna connections.
    • Be careful to not pull the antenna wire too hard, you may cause damage to the connection permanently and/or motherboard.
    • The screwdriver is only being use to demonstrate which wire to remove. The screwdriver can potentially damage the motherboard if used improperly.
  3. HP Compaq Presario V6000 Wifi antenna card Replacement: passo 3, immagine 1 di 1
    • After removing the connection cable, remove the two screws that hold the wireless card to the motherboard.
    • Then gently remove card without causing any damage to card itself or surrounding parts.
Conclusione
Hunter Griffin
Membro da: 10/11/16
104 Reputazione
1 Guida realizzata
Texas Tech, Team 38-4, Bennett Fall 2016 Membro di Texas Tech, Team 38-4, Bennett Fall 2016
TTU-BENNETT-F16S38G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 713
